dallis11
Feb 13, 2020Aspirant
linux du command (disk use) not returning correct disk usage
The GUI webbrowser listing appears to be correct however du via linux is not correct. I ran a scrub/balance and still not showing correctly. Previously this worked. I'm seeing this on both my 4312 an...
Feb 13, 2020Guru - Experienced User
dallis11 wrote:
The GUI webbrowser listing appears to be correct however du via linux is not correct. I ran a scrub/balance and still not showing correctly. Previously this worked. I'm seeing this on both my 4312 and 4360 NAS units.
Use btrfs fi df https://ohthehugemanatee.org/blog/2019/02/11/btrfs-out-of-space-emergency-response/
