carpeDiem3
Jan 13, 2025Aspirant
Looking for Schematics for RN526 & RN626 MB v3.0 Motherboard (Netgear ReadyNAS 526X)
Hi everyone,
Would anybody happen to know where I could find the schematics for the RN526 & RN626 MB v3.0 motherboard from a Netgear ReadyNAS 526X?
I have a broken header on the motherboard, and I need to determine if the damaged pin is actively used or not. Any help locating the schematics or a detailed pinout for this board would be greatly appreciated! or where I could get a replacement if need be
Thanks in advance
- SandsharkSensei
Netgear has never made schematics available. They don't even have authorized repair shops.
If I had access to them, I could help a lot more folks with faulty NAS and maybe fix a couple I have "for parts".
- carpeDiem3Aspirant
yeah that's my issue as well, my NAS wont turned on the welcome screen displays, the Nic cards link lights are on, and the fan runs, but that's it , I verified that the power supply provides the correct voltage to all the pins and now I am stuck. I want it at least up long enough to pull the last data of my raid. and I don't want to purchase a discontinued device used for some outrages prices.
- SandsharkSensei
There are a number of ways to get the data off your drives without having to purchase another NAS. But they all start with needing a way to connect them to a PC.
Assuming your volume is intact (so you don't need "recovery" software), you can use a generic Linux system with MDADM and BTRFS installed. That's easiest if you can boot the PC to Linux, but can be done with a virtual machine. This method does take some Linux knowledge or a lot of coaching. But you can also use a ReadyNAS virtual machine. See Mounting-ReadyNAS-drives-in-a-virtual-NAS-for-data-access.
The following steps can help determine if the pin is used:
Using a meter in both the ohms and diode modes, in both polarities, check for continuity from each of the voltage sources and ground. If it's a direct short, then you've found what it does. If there is a not shorted and not open reading, it's connected to something and likely used. If it's open, it's still a mystery, but the chances are good it's unused.
