Kgallucci's avatar
Kgallucci
Mac permissions RAIDiator 4.2.31
I am running a graphics department with many mac and windows users. There are some files on the NAS that only certian macs (accidentally) have permissions to see. I want to make a hard copy of the ...
  • StephenB's avatar
    Sep 11, 2020
    This might speed things up...
    First, on the CIFS screen, scroll down to the "advanced cifs" section in both shares and make sure it's configured as shown below:
    After you'd done this click apply, and go back to the advanced options screen:
     Also check the "Set ownership" box before you click apply.  The check will immediately clear when you click apply.  It will make sure that all the files and folders in the share have these permissions set correctly.
ProSupport for Business
