gator1350
Nov 08, 2019Aspirant
Management Dashboard for ReadyNas NVX
I had a power supply on my RN4200 and after replacing it, I cannot get to the management window. I can see the shares and mount them to the MAC, but i cannot do any administration to it. It is atac...
gator1350
Nov 11, 2019Aspirant
I have tried that with the password I gave it, a new password I assigned it, and the original admin/password, but nothing.
It keeps asking for userid and password, and the message says something about Control Panel.
Thank You,
Steve
gator1350
Also, I am using a Macbook Pro. I have also direct attached it to my PC and cannot connect. When I put the address in the browser, the only thing that shows up is the shares window without any shares displaying.
- gator1350Nov 11, 2019Aspirant
Please see attached screenshot.
- StephenBNov 11, 2019Guru - Experienced User
That's because you are browsing to https://nas-ip-address. Browse to https://nas-ip-address/admin instead.
The username has to be admin.
If you can't log in, then you can try doing an OS reinstall, which will set the password back to netgear1 (which is the default for your NAS). Instructions are on pages 21-22 of the hardware manual here: http://www.downloads.netgear.com/files/GDC/RNDU2000/ReadyNAS_Ultra_UltraPlus_NVX_Pro_HW_en_8July11.pdf
- gator1350Nov 11, 2019AspirantI have tried admin/password, admin/netgear1, my user id and password.
Nothing, will try the reload next as all my data was moved to another device till I get this working again.- SandsharkNov 11, 2019Sensei
Nothing, will try the reload next as all my data was moved to another device till I get this working again.Unless you never changed the default admin password or you have done an OS re-install, you need to use user admin and the pasword you chose for the admin password when you set up the NAS.
Also, you really want to use https://, not http://, though the latter is supposed to re-direct to the former.
