ravx25
Apr 10, 2016Tutor
Managing Files in Mapped Drives
Hello all, I've managed to map network drives to my ReadyNAS 204 on my local PC, but I'm unable to delete or cut the files from the map drive. When I go into the security for the share on the Re...
ravx25
Apr 12, 2016Tutor
I had default options set up but copied yours here in the screenshot, however I still can't delete files from the share using my local pc. I'm setting up the mail drive as I would any map drive.... I go to map drive, type in the UNC, make sure reconnect is chosen and hit finish. I can add folders and delete files I make. The files I want to delete, however, are coming from an app called Sabnzbd putting them on the share one downloaded. I'm thinking that has something to do with it though.
- BrianL2Apr 12, 2016NETGEAR Employee Retired
Hi ravx25,
There is a similar thread posted in the community that may help you with this permission problem that you've encountered.
Kind regards,
BrianL
NETGEAR Community Team- ravx25Apr 12, 2016Tutor
Thank you, Brian. That thread was indeed able to help me out. Turns out it was Sabnzbd after all.
