Nov 27, 2014Guru - Experienced User
Maximum Snapshot Age (per share)
Although the snapshots are automatically thinned, some of them are still retained forever. So at some point I still need to go in and manually delete them. I'd like a setting for each share which ...
mdgm-ntgr
Nov 27, 2014NETGEAR Employee Retired
Manual snapshots will not be deleted automatically, but other snapshots should be deleted if there is insufficient free space on the data volume. Have you not found this to be the case?
