patrice_readyna
Jan 30, 2015Aspirant
Memory stick for a ReadyNAS X6
Hi, I'm trying to find a memory for my ReadyNAS X6 Rev B. I suspect mine has fried according to the light blinking pattern. Searching this forum for X6 yields no results. Anyone could direct me to...
mdgm-ntgr
Feb 08, 2015NETGEAR Employee Retired
The Infrant ReadyNAS X6 is one of the early Sparc ReadyNAS models.
What do you mean by "which machine is compatible with the x6?" Do you mean which machine you can move your disks across to from the x6? Or something else?
