haupin
Aug 03, 2011Aspirant
Memory upgrade for ReadyNAS Pro 6 Pioneer & Ultra
Hi. I've got a ReadyNAS Pro Pioneer that keeps hanging at random points during resync, rendering it useless as it'll fail anywhere between 5 minutes and 5 hours after booting. I read in a different...
mdgm-ntgr
Aug 03, 2011NETGEAR Employee Retired
Upgrading the memory is not supported. The stock RAM is plenty.
Could you please run a few passes of the "Memory Test" and then run the "Disk Test" using the boot menu?: http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu
