haupin
Aug 03, 2011Aspirant
Memory upgrade for ReadyNAS Pro 6 Pioneer & Ultra
Hi. I've got a ReadyNAS Pro Pioneer that keeps hanging at random points during resync, rendering it useless as it'll fail anywhere between 5 minutes and 5 hours after booting. I read in a different...
mdgm-ntgr
Aug 04, 2011NETGEAR Employee Retired
The Pro Pioneer is covered by a 3 year warranty. So I'd suggest testing the memory and if it's bad contact NetGear tech support with the results.
Back in the days when memory upgrades were supported a Jedi said that only non-ECC modules were supported.
NetGear had to remove the compatibility list for memory as new incompatible revisions of memory modules were introduced but with the same module number.
