leo037's avatar
leo037
Luminary
Mar 15, 2023
Migrated from ReadyNAS 428 to ReadyNAS 628. Have SSL key host issue in Admin
Hey everyone
I just got a 628 and got it tested and ram upgraded.
Popped in the drives from my 428 and working as expected.
However, when I try to turn services on/off. I get "invalid SSL key host" error and can't do anything but click ignore and no settings change.
What do I need to do to fix this?
  • StephenB's avatar
    Did you change the hostname?
    Try going into System >> Settings >> HTTPS >> and change the SSL Key Host value to match the hostname (host-name.local)
    You might need to reboot afterwards - not sure.
    • leo037's avatar
      leo037
      Luminary
      No I can't do that because it tries to verify the host key before doing anything in settings.
      I need the command line stuff to fix this
      • StephenB's avatar
        Try an OS reinstall from the boot menu.
        That will also
        • change the admin password back to password
        • reset the network connection to factory default (no bonding, DHCP)
        • disable volume quota (which can be turned back on in the volume settings wheel).
        It shouldn't hurt any data.
ProSupport for Business
