Paul608085
Mar 27, 2016Tutor
Monitoring CPU and RAM Usage (linux-dash and alternatives)
I have had a RN104, (OS 6.4.2), for some time now but have often thought that it was running a bit slow. For example I have DVBLink TV Server installed and when opening it up from another device it o...
- Mar 31, 2016
That was just my opinion. It isn't bogus or misleading, just only so much the little Marvell Armada CPU can do :) Honestly, has I said it serves up my media files perfectly. I just found running some of the varous apps (Plex, the Virus scan, pigwo, and enabling iTunes or DNLA) running at the same time while trying to access the files via Plex (streaming mkv files) it isn't effient and uses a lot of CPU. That is why I mentioned running top and saving the output so you can see the CPU use and Waits.
The way we have it set up is probably simple but more or less it is the centralized storage for our home. All of our computers back up to it. It also serves our media (Music and Movies) via Plex. Plex is running on Ubuntu and NFS mounting the NAS shares. Once a week the 104 sends its data to another PC in the house with lots of storage who shoots it up to Crashplan. Documents, photos, computer backups, and music mostly - I don't back up the movies since I have the physical media still.
Down the road I'm sure I'll expand my Ubuntu server with a raid card and ZFS or some other files system/RAID and remove the 104 since it would be significantly faster with regards to disk I/O and network. But so far NAS to TV or other streaming device it is ok and I can tolerate the 20 - 30MB/Sec transfer rate it seems to see when transferring files.
So yeah, it is good at one or two things but not for running Plex or some of the more CPU intensive applications while also serving up media. I think that is pretty fair to say. It really comes down to the CPU and Memory amount it has as the limiting factor.
saf1
Mar 28, 2016Aspirant
Via command line top is going to be the primary tool of choice within the ReadyNAS 104's distro. It will more or less tell you what you need to know. You can just create a small script and have it write to a file. Then using awk, cat, grep, or whatever else you are comfortable with, just parse out the date, time, CPU / US (User), SY (system), NI (Nice), ID (Idle), and WA (Waits). If you want memory grab that too if you are so inclinded. What you want to do is throw this data into excel, make a pivot table, add date/time, user, sys, and idle. Here you will see how your ReadyNAS is doing vs. load. Pretty simple honstly.
Pay attention to the wa column w hich is I/O wait - or time waiting for I/O to complete. When that number is high you know you have reached the ReadyNAS's capacity with regards to I/O throughput and/or CPU.
Note: I thought someone had a application in the app store, for free, that did a single page presentation with regards to CPU, disk space, ram, etc. Again, I do not run any apps on my box has it only serves up files/media. The box does well with that but anything else running on it tends to bog the little CPU down. Mine is running 4x6 TB WD reds.
