xbmcgotham
Aug 12, 2021Tutor
Monitoring UPS over SNMP for Readynas nv+ v2.
Hi, I cant understand why the Readynas is not switching off when a low UPS battery level is reached. As you can see on the screenshots, I am monitoring a UPS over SNMP and it can ready the values...
Aug 12, 2021Guru - Experienced User
Is the UPS also protecting the switch(es) between the NAS and the UPS?
Have you also tried connecting the UPS to the NAS with USB?
- xbmcgothamAug 12, 2021Tutor
Hi StephenB ,
The power court of the NAS is going into the UPS.
The UPS is a serverrack UPS and only has power and a network connection, which is used to communicated with the other devices on the network. No USB available.
- StephenBAug 12, 2021Guru - Experienced User
xbmcgotham wrote:
No USB available.
This is the Smart-UPS X 2200? The manual (attached) says there is a USB port.
- xbmcgothamAug 13, 2021Tutor
Hi,
Its not completly the same as the document. mine is a SMX2200HV
The manual does look to show a usb, not sure why I never seen it. I will have another look on the UPS. :-)
Question:
1. why would I connect the NAS with the UPS using USB cable? Does this not defeat the purpose of the network monitoring option?
2 If all would have worked correctly without using a USB cable, what would be the value on which the NAS should switch off when using the network monitor option? Low battery? Any idea?
Thanks
