JohnTemple
Nov 24, 2019Follower
mount_block_root +25e Help - any ideas how to fix this
Help - Can't get into boot menu or do anything with my ReadyNAS RN31400. Had a ower cut and the above error appeared. Nothing working - can't get into BOOT Menu using the reset button, or boot fr...
arlington
Apr 13, 2020Aspirant
I removed all six drives, powered up and still see the message "mount_block_root +25e"
Is there a way to repair the unit?
If not, do I have options for recovering the data that is stored across those 6 drives?
Apr 14, 2020Guru - Experienced User
Best not to duplicate your posts.
- Mfisch23Apr 14, 2020Tutor
We lost power on Tuesday and i just realised now that my ReadyNAS isn't working i see the same Mount_Block_Root +25e error on my LCD. I removed all the drives and booted it but still get the same message. Is there anything i can do? i have a RN31600 so it's no longer under warranty. Am i screwed?
- JohnCM_SApr 14, 2020NETGEAR Employee Retired
Hi Mfisch23,
Have you tried doing a USB boot recovery? You may try that first and see if you can recover your NAS using that method. You may check this article for the procedure.
I will try that now and i will let you know. Thanks for the responce.
Mike
