JohnTemple
Nov 24, 2019Follower
mount_block_root +25e Help - any ideas how to fix this
Help - Can't get into boot menu or do anything with my ReadyNAS RN31400. Had a ower cut and the above error appeared. Nothing working - can't get into BOOT Menu using the reset button, or boot fr...
Karnis
Dec 07, 2020Aspirant
Just as "MCJCALVI80" said.
I tried 6 different USB's, then I tried running the USBrecovery tool one last time, this time I right-clicked the file and ran the file as administrator. Formatted the USB-drive with the USBrecovery tools built-in format function and then created the boot... Finally worked like a charm!
jimk1963
Apr 04, 2021Virtuoso
+1 for USB format... right click the usbrecoverytool.exe and choose "run as administrator" and then the recovery worked first time on RN314, after several failed attempts without doing this. process takes 60 seconds or so.
