JohnTemple
Nov 24, 2019Follower
mount_block_root +25e Help - any ideas how to fix this
Help - Can't get into boot menu or do anything with my ReadyNAS RN31400. Had a ower cut and the above error appeared. Nothing working - can't get into BOOT Menu using the reset button, or boot fr...
pratik18999
Apr 14, 2021Aspirant
I removed my storage disks from slots (just don't want to loss any data) and now i am doing usb recovery tool.
NAS was saying that " boot from external drive" from last 15 mins
how much time it will take to finish?
IS it working or not?
mdgm
Apr 14, 2021Virtuoso
It shouldn’t take very long, perhaps a minute or two and then the system should power off.
You could try booting without the USB connected. If it has worked then you won’t get the mount_block_root error anymore.
If it’s still stuck on booting off USB after 15 minutes that would suggest either an incompatible USB key, or that the steps to create a USB Boot Recovery key were not followed correctly.
Perhaps try a different USB key.
- jimk1963Apr 14, 2021VirtuosoRead the earlier notes about copying the data onto the usb stick as Windows administrator. My install kept failing until I did this and then it ran successfully the first time after.
