JohnTemple
Nov 24, 2019Follower
mount_block_root +25e Help - any ideas how to fix this
Help - Can't get into boot menu or do anything with my ReadyNAS RN31400. Had a ower cut and the above error appeared. Nothing working - can't get into BOOT Menu using the reset button, or boot fr...
pratik18999
Apr 14, 2021Aspirant
thank you so much.
All of you saved me
Third USB drive worked.
- stephenloachMay 10, 2021AspirantHi
Can anyone list what usb stick worked please. Mines been like this since 1st lock down :(- mdgmMay 10, 2021Virtuoso
There are so many different USB keys out there.
Make sure you run usbrecovery.exe as Administrator.
An older USB key maybe is probably more likely to work.
Which model ReadyNAS do you have and where do you get stuck in the process?
What happens when you try to boot off USB?
- stephenloachMay 17, 2021AspirantHi
I have a RN316. It was under warranty but when approached the supplier they wasnt a authorised retailer so netgear wouldnt help and neither did they.
I have tried about 5 usb sticks with no joy. The nas doesnt seem to recognise the usb drive. I hold the reset but while powering on, tge usb stick light blinks to say connected and thats it, nothing staight to rout block etc. The sticks led doesnt change state so im out of options. I have ordered an old job lot of usb sticks from ebay, after this im at the end of the road
Sent from Samsung Mobile on O2
Get Outlook for Android
