JordanThompson
Apr 29, 2016Aspirant
Moving from 104 to 204
I have a 104 system with 3 two terabyte drives. How hard it is to replace the NAS hardware with a 204? Can I just pop the drives out of the 104 and pop them into the 204?
JordanThompson
May 19, 2016Aspirant
I have decided to get the 314 model instead of the 204.
Can I assume that the switch from 104 -> 314 will be the same as suggested from 104 -> 204?
What happens to any configuration I have done to the 104 (IP, Apps, backups, etc) Can I back this up on the 104 and recover it to the 314?
May 19, 2016Guru - Experienced User
You uninstall all the apps, then power down the system and migrate the disks (keeing the order). It then update the OS for x86 processor. Data and configuration should be preserved. After it settles down re-install the apps.
I always do recommend a backup, especially when you are playing with disks.
- JordanThompsonMay 19, 2016Aspirant
OK, so here is what I have:
- back up data from 102 (doing that automatically already, but excellent suggestion)
- remove apps from 102
- stick a spare drive into 314
- power up 314
- upgrade software 314
- power down 314
- power down 102
- move disks from 102 to 314 (keeping their order left-to-right)
- power up 314
Does it make sense to back up the configuration of 102 and then load it into 314? Its not like there is a lot of configuring, but that's what its there for after all.
- kohdeeMay 19, 2016NETGEAR Expert
Personally, I do not like backing up and restoring configs unless it is plain text (like a switch config). Depending on how expansive your settings are, it might be easier to just reconfigure quickly. RN314 is a way huge improvement than RN104. I use the RN314 at my desk a majority of the time.
- StephenBMay 19, 2016Guru - Experienced User
JordanThompson wrote:Does it make sense to back up the configuration of 102 and then load it into 314? Its not like there is a lot of configuring, but that's what its there for after all.
You shouldn't have to. The config should survive the disk migration.
- JordanThompsonMay 25, 2016Aspirant
I made the switch and everything seems to be working fine. The only issue I have is that all of the app icons and some of the other icons are broken. I read somewhere (for the life of me I can't find it) that to fix this, you just need to delete the icons in a folder on the reaynas.
Anyone know if this is true can you please tell me where/what I need to remove?
thanks in advance.
