Pedro45
Nov 26, 2019Aspirant
Multiple NAS drives in a non-RAID (JBOD) configuration?
I have a Netgear ReadyNAS214 (latest OS) which had a single drive as it was/is intended as a backup to machines on the network – "JBOD", no RAID required or wanted. When I introduced a second dri...
- Nov 26, 2019
Did you try to do a factory default? That would be needed if you were still using XRAID. I thought based on your earlier post that you have already gone back to JBOD. FWIW, it wasn't needed to simply add a JBOD volume.
In an event, if that is what you are doing, then the NAS admin password has been reset to password. The NAS will by default use XRAID. So when you get past the wizard, you should
- switch to flexraid
- destroy the data volume
- create two jbod volumes, one for each disk
There is no need to wait for the XRAID volume to build/resync.
Nov 26, 2019Guru - Experienced User
Pedro45 wrote:
Obviously I'm missing something needed to achieve the desired "dual JBOD" configuration. Any suggestions?
Change to flexraid before you add the second disk. You do that on the volume page - if there is a green stripe on the XRAID control, then XRAID is enabled. Click it, and the system should change to flexraid.
Then select the disk on the volume page after you hot-insert it. If the disk is used, then you'll need to use the format control on the page. After that, create a second JBOD volume.
I suggest reading through chapter 2 of the software manual ( http://www.downloads.netgear.com/files/GDC/READYNAS-100/READYNAS_OS_6_SM_EN.pdf ).
Pedro45
Your first para sounds like a contradiction.
I have read that Chapter 2. All I took away from that was a sore head, and re-reading it didn't help one bit. I came here hoping to find a simple step-by-step solution.
- StephenBNov 26, 2019Guru - Experienced User
I fixed the typo. And my response above does provide the step-by-step solution
- switch to flexraid (making sure there is no green stripe on the xraid control)
- add a disk
- format if needed
- create a new volume using that disk
Then of course create shares on it.
Though flexraid may sound complicated, using jbod with one disk per volume isn't hard.
- Pedro45Nov 26, 2019Aspirant
I've copied all the 100GB of data off the #1 drive and I'm following the Installation Guide (pp9-11) to reinitialise/reformat that drive. Except I can't get past the wizard's setup page wanting the admin password. I give it the new pswd, hit Enable Password Recovery/Reset Button and then Next/Next/Apply and it errors with Failed to set Admin Account Password and Failed to set Recovery method.
If I select IGNORE and Apply, it pops up the error box again. Can't ignore, can't satisfy the b@#$%^ wizard, can't proceed!!
What was once a useful single drive NAS is turning into an absolute nightmare.
