userreadynas
Jul 01, 2019Aspirant
MySQLON x86 version anyone?
Trying to enable MYSQL on a: ReadyNas Ultra 2 version 4.2.31 Has anyone still the x86 version for Radiator 4.2.31 somewhere for download? The following links are not for this version unfortu...
Jul 01, 2019Guru - Experienced User
userreadynas wrote:
Has anyone still the x86 version for Radiator 4.2.31 somewhere for download? The following links are not for this version unfortunately: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/MYSQLON/m-p/653674#M104194
The second (quoted above) claims to be for 4.2.x firmware. A direct download is http://www.readynas.com/contributed/super-poussin/PRO-MysqlOn_1.0.bin
Another option is to convert your ultra to OS-6. You could then purchase a mysql installer from www.rnxtras.com (https://rnxtras.com/readynas-os6-x86)
userreadynas
Thanks, the PRO did work for me.
Upgrading to version 6? Did not know this was possible. Is this easily done without to many known hickups?
- StephenBJul 01, 2019Guru - Experienced User
Lots of folks have done it, with only a few having issues.
The process does involve a factory reset (so you would need to restore all the data from backup). Also, Netgear won't support NAS that have been converted.
