broad01
Feb 05, 2020Tutor
NAS 104 Locked Up
NAS has locked up. Can not access. Can not even ping. See attached photo of the display. Will not soft shutdown using power button. Any ideas?
broad01
Feb 13, 2020Tutor
I am trying to post the results, but my posts keep disappearing???
Does the Community System automatically delete posts with telnet Commands?
Tried to post my results 3 times and they disappear........
OK managed to add my results as a ODF. Any further suggestions?
StephenB How do you create the gray boxes you post commands into?
broad01
Feb 13, 2020Tutor
I will try again.
Here are the results, any further suggestions?
Spoiler
# rnutil chroot
mdadm: /dev/md/0 has been started with 4 drives.
mdadm: /dev/md/1 has been started with 4 drives.
mdadm: /dev/md/data-0 has been started with 4 drives.
mount: mounting LABEL=0e346740:data on /data failed: No such file or directory
Spoiler
root@3EP134E501109:/# btrfs check /dev/md127
checksum verify failed on 27623876067328 found 7B90F733 wanted 317347E8
checksum verify failed on 27623876067328 found 092ADC2A wanted 80665FC4
bytenr mismatch, want=27623876067328, have=6109277914453778088
Couldn't read tree root
Couldn't open file system
Spoiler
root@3EP134E501109:/# btrfs device scan
Scanning for Btrfs filesystems
root@3EP134E501109:/# btrfs fi show
Label: '0e346740:data' uuid: a5008274-7a77-450f-b098-dff8dd3dc285
Total devices 1 FS bytes used 20.10TiB
devid 1 size 21.82TiB used 21.77TiB path /dev/md127
Spoiler
root@3EP134E501109:/# mount /dev/md127 /data
mount: wrong fs type, bad option, bad superblock on /dev/md127,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so.
Spoiler
root@3EP134E501109:/# dmesg | tail
[ 153.836981] disk 2, o:1, dev:sdc3
[ 153.836988] disk 3, o:1, dev:sdd3
[ 153.837203] md127: detected capacity change from 0 to 23989784936448
[ 154.337435] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
[ 229.016409] BTRFS: device label 0e346740:data devid 1 transid 1575622 /dev/md127
[ 270.024702] BTRFS: has skinny extents
[ 270.241458] BTRFS (device md127): bad tree block start 17761992830035128566 27623876067328
[ 270.241879] BTRFS (device md127): bad tree block start 17761992830035128566 27623876067328
[ 270.241917] BTRFS: failed to read tree root on md127
[ 270.300229] BTRFS: open_ctree failed
Adam
- StephenBFeb 13, 2020Guru - Experienced User
broad01 wrote:
I will try again.
Spoiler# rnutil chroot
Spoilerroot@3EP134E501109:/# btrfs check /dev/md127
Spoilerroot@3EP134E501109:/# btrfs device scan
Spoilerroot@3EP134E501109:/# mount /dev/md127 /data
dmesg | tail or so.
Spoilerroot@3EP134E501109:/# dmesg | tail
Adam
The data volume is corrupted. RAID recovery software might work.
