space-bob
Jun 02, 2023Aspirant
NAS Debian package Update Question
Hi All, I'm trying to squeeze the last remaining life out of my Nas Duo v2. I came across this possible solution to fix the ssl issue: https://github.com/rdynsxtrs/r5bin/tree/master/apach...
Jun 02, 2023Guru - Experienced User
I am thinking that you actually have the original Duo (v1).
The original Duo
- runs 4.1.x firmware
- has "ReadyNAS Duo" on the front panel
- often has other labels that say RND2000 v2 (which don't mean what you think).
The Duo v2
- runs 5.3.x firmware
- has "ReadyNAS Duo v2" on the front panel.
space-bob
On the sticker on the bottom it says RND2120 v2.
So I guess it is not the version I think it is - is there any option available for my model?
Thanks!
