space-bob
Jun 02, 2023Aspirant
NAS Debian package Update Question
Hi All, I'm trying to squeeze the last remaining life out of my Nas Duo v2. I came across this possible solution to fix the ssl issue: https://github.com/rdynsxtrs/r5bin/tree/master/apach...
space-bob
On the sticker on the bottom it says RND2120 v2.
So I guess it is not the version I think it is - is there any option available for my model?
Thanks!
Jun 02, 2023Guru - Experienced User
There is no add-on for the SSL version error.
What you can do is
- Use Edge in IE Mode
- Configure FireFox to allow TLS 1.0 connections
- Modify virtual.conf in the NAS to allow https connections to frontview.
The last option is described here:
The "V2" just signifies a minor hardware revision (a component change).
Very poor branding on Netgear's part, we've been dealing with the confusion here for about 12 years now.
