space-bob
Jun 02, 2023Aspirant
NAS Debian package Update Question
Hi All, I'm trying to squeeze the last remaining life out of my Nas Duo v2. I came across this possible solution to fix the ssl issue: https://github.com/rdynsxtrs/r5bin/tree/master/apach...
Jun 02, 2023Guru - Experienced User
I am thinking that you actually have the original Duo (v1).
The original Duo
- runs 4.1.x firmware
- has "ReadyNAS Duo" on the front panel
- often has other labels that say RND2000 v2 (which don't mean what you think).
The Duo v2
- runs 5.3.x firmware
- has "ReadyNAS Duo v2" on the front panel.
Lucifer24
Aug 08, 2023Aspirant
Hi.
I have a ReadyNAS NV+ v2 running firmware version 5.3.13 and having the same problem.
It says on the github page "The code provided does not work for the similarly named SPARC systems."
How do I check what system i I have? Or is the error I'm receiving a sure confirmation that I'm having i SPARC system?
- Lucifer24Aug 08, 2023Aspirant
Figured it out. ssh to nas and run uname -a. It says I'm running a arm system. Still stuck with the not a debian format error, but have decided to install open media vault on the nas, so it doesn't matter anymore
