PMNG's avatar
PMNG
NAS102 CLI close down
Hi All,
Just installed my first NAS, a 2nd hand NAS102 whixh is near my modem in another room.
With WakeMeOnLan.exe I can switch it on remotely with a single click on a CMD shortcut.
I cannot find a way to shut it down with the same ease, or have it shut down automatically after a certain time of no acitvity. Is there a way ( I don't want it running all the time ) ? Going into the admin page each time seems a waste of time :-)
Thanks,
Alex
  • StephenB's avatar
    You can configure scheduled shutdowns (and startups) via the power tab in the admin web ui.
    If ssh is enabled on the NAS, you can use a utility called putty to send a shutdown command.
    https://www.chiark.greenend.org.uk/~sgtatham/putty/latest.html
    https://the.earth.li/~sgtatham/putty/0.71/htmldoc/
    I haven't tried using putty for this - so check the manual. But I believe the right windows CLI command would be
    putty.exe -ssh -2 -l root -pw nas-admin-password -m c:remote.cmd nas-ip-address
    remote.cmd is a file on the PC that has the shutdown command in it.  I suggest using rnutil rn_shutdown
    You can also do this from the putty gui (there is an option to enter a remote command there also).  But it would be easier to script it if you use the putty CLI interface.
    • PMNG's avatar
      PMNG
      Thanks for helping StephenB  !
      For anyone reading this in the future:
      For me the "scheduled shutdowns (and startups) via the power tab" were no option. I want to do it (for now manually) before closing down my pc.
      So here is my magic formula (there might be others, this worked for me):
      Like Stephen said:
      - download Putty, make sure the PATH enviromental is set.
      - turn on SSH on the NAS
      then make a new shortcut (right click in explorer, new>shortcut) and give it this value:
      cmd.exe /c plink -ssh -2 -batch IpAdressToNas -l root -pw YourPassword rnutil rn_shutdown
      ( off course change the IpAdressToNas (can also be found by WakeMeOnLan) and YourPassword )
      then call it CloseNas or something of your liking. Double Click it and the NAS will close.
      some explaining:
      /c = no terminal window  (for testing you can use /k instead)
      -ssh = force using SSH
      -2 = force SSH V2
      -batch = ignore the "press return to start the session"
      -l = user
      -pw = password :-)
      Enjoy
      Alex
ProSupport for Business
