carlocki
Nov 22, 2020Luminary
need to solve hdd failure on a Nas RN104
my 4x 4 tb rn104 nas is having problems a couple of days ago mechanical noise and after 20 hours or recovery a second failure and again 20 hours of recover this is the report then the second fa...
- Nov 23, 2020
Why are you asking over and over? Just get the Ironwolf. It'll work fine.
Users here have had a better experience with Ironwolf than Barracuda.
Sandshark
Nov 22, 2020Sensei
I can't see your pictures until a moderator approves them, so can't help a lot with the root problem. But I can say that cloud backup will take an eternmity and you may not have that amount of time. Doing a local backup now while you still have access to the files is the right approach.
- carlockiNov 22, 2020Luminary
I have an antec system for single hdd. I want to buy a 4Tb and do the first physical bckp
the problem i cannot find 4tb st4000m000 as the originals
also ebay only US i live in Italy
- StephenBNov 22, 2020Guru - Experienced User
It looks like the resync failed on disk 4 (per the first screenshot). The second one says a disk test is in progress, it's not clear what the timing is. However, it looks like disk 4 might have failed. The best way to confirm would be to power down the NAS, and connect the disk to a Windows PC, and test it with SeaTools. You can connect with a USB adapter/dock if you can't connect it with SATA.
Honestly I wouldn't use that disk. Some recent barracuda drives have switched to SMR technology which isn't a good choice for RAID. Look for a 4 TB Seagate Ironwolf instead. ST4000VN008 is the currently shipping model for that.
i have no money
change 4 disk for 1 failed is out of discussion
i need just 1 hdd can i put another 4tb ?
can i have 3 st0000m000 and one st0000m004?
