JohnS530
Mar 08, 2021Guide
Netgear NAS drive will not restart
NAS drive will not restart. System starts and gets to 36% and displays "kthread_data+7". 36%. I have to hard power down, and restart. It gets to the same point in a couple of minutes. It has be...
- Mar 08, 2021
It's crashing.
Try booting it up read-only. Pages 74-75 in the hardware manual describe how to do that with an RN314. https://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
If this works, then back up the files on the NAS.
If it doesn't work, you should probably contact paid support via my.netgear.com. Gearhead support isn't enough. The mods here ( JohnCM_S or Marc_V ) can assist you in getting to the right support.
Mar 08, 2021Guru - Experienced User
It's crashing.
JohnS530
Mar 08, 2021Guide
I was able to use your suggestion to get the unit to boot. I am now doing a full backup which will be done shortly.
Once the backup is complete, do I need to reload the firmware OS?
Is there a way to refresh the OS, without having to reload all data from backup?
Thanks for your help.
- StephenBMar 08, 2021Guru - Experienced User
At this point we don't know what is triggering the crash.
You can download the log zip file from the web ui, and look in system.log, kernel.log, and system-journal for clues. There's a lot of info in there that you won't see on the screen. Disk-info.log will also give you the smart stats for the disks (reallocated sectors, etc). That might give us enough information to understand what is happening.
The other way (brute force, but sometimes quicker in the end) is to do a factory default. That will reformat the disks and reinstall the OS. Then you'd need to reconfigure the NAS, and restore the files from your backup.
You can try an OS-reinstall - that is also described in the hardware manual. That should preserve your data and almost all settings. The admin password will be reset back to password. In addition, the network will be set to the default DHCP, and the volume quota (which is on the volume settings wheel) will be disabled. It is worth a try (after the backup of course). But I suspect it won't resolve your problem.
- JohnS530Mar 08, 2021Guide
I will try the OS-reinstall as a starting point.
thanks.
