kontech
Jul 15, 2021Aspirant
NETGEAR ReadyNAS 3138 storage limits
I'm looking to upgrade disk storage on NETGEAR ReadyNAS 3138. There are currenly 2 x8TB drives and I was looking to add two 14TB drives. I read somewhere that there's no hard limit for drive size but...
- Jul 15, 2021
kontech wrote:
There are currenly 2 x8TB drives and I was looking to add two 14TB drives. I read somewhere that there's no hard limit for drive size but want to make sure it will work
There is no known limit , and Netgear's HCL shows 16 TB disks for the RN3138. So you should be fine.
If you are using XRAID, this will expand your volume from 8 TB (~7.27 TiB) to 30 TB (~27.28 TiB).
Jul 15, 2021Guru - Experienced User
