NathanWoodruff
Feb 11, 2021Aspirant
Netgear Readynas deleting file mediaID.bin
I have ReadyNas Firmware 6.10.4 and I've copied a windows backup to my readynas. I no longer need this backup and I've deleted it except for the mediaID.bin file. Readynas refuses to delete the file ...
- Feb 14, 2021
Feb 12, 2021Guru - Experienced User
I am wondering if bit-rot protection is enabled on the share. I have a vague recollection of something similar happening when the a file checksum failed and bit-rot protection couldn't fix it. It was a long time ago, so I might not be recalling this correctly.
NathanWoodruff
Feb 12, 2021Aspirant
StephenB wrote:I am wondering if bit-rot protection is enabled on the share. I have a vague recollection of something similar happening when the a file checksum failed and bit-rot protection couldn't fix it. It was a long time ago, so I might not be recalling this correctly.
- StephenBFeb 12, 2021Guru - Experienced User
NathanWoodruff wrote:
Thanks, that rules that possibility out.
Let us know what happens when you try to delete it with ssh.
- NathanWoodruffFeb 14, 2021Aspirant
- StephenBFeb 14, 2021Guru - Experienced User
I'm glad you were able to delete it.
It is a little odd that the permissions reset didn't result in write access.
