DeepakSondur's avatar
DeepakSondur
NetGear ReadyNas316 Two types of Data Visible Type 1 & Type 5
Ready NAS 316 built this with 3,3,3,3,4 & 4 TB respectively effectively gives me about  13.62 TB of Space on Traditional Raid 5 configuration or 14.5 TB on X-Raid 5 configuration. ( I am not sure what configuration is this configured)
Now coming to my sreenshot of the Admin page, there are two volumes
Data-0 containing 13.62 TB  Data, Free 0 TB, Type is Raid 5
Data    containing 931.38GB Data Free 0 TB, Type is Raid 1
Now I am unable to access the data and the file sturucture on my device.
Background:
I Built this device over a period of time by accumulating HDD as time permited.
I did not know that we should not use the NAS beyond 90% of the allocated space, which I did.
One day, Disk one has failed and the compression has happened and was not able to access the data. I got one new 4TB HDD and inserted into the drive, but nothing happened.
I tried bit if other activities like Jack out and Jack in of the HDD and reboot, which never helped., I guess the issue is something different with the NAS drive.
Its been over a year, I have switched it off and now, because of the Lockdown, I have brough this out to restore my NAS drive so that I can access my data.
Any help on this regard will be highly appericiated and any more inputs required please put it accross.
Can anyone comment, can two type of Data be found on NAS, like Type 1 & Type 5.
  • In addition, you are likely seeing that the two volumes are inactive correct?
    Do you have a backup of the data?  If you do, then do a factory default, reconfigure the NAS, and restore the files from your backup.
    Otherwise, the best way to resolve this is to contact paid support (my.netgear.com).  You can ask for per-incident support.  Don't purchasing Gearhead unless the mods say you should ( JohnCM_S or Marc_V )
    It is possible that per-incident support is enough to get the volume mounted.  But if there is file corruption you will need data recovery.  https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service
    It's because you have unequal size disks.
    In order to use all the space you need to have two different RAID groups on the disks.  One is 3x6TB RAID-5 (15 TB, or ~13.6TiB).  The second uses the remaining space on the 4 TB drives, and is 2x1TB RAID-1 (1 TB, or  ~0.9 TiB).  These two RAID groups are then concatenated into a single volume.
    If you look at the partitioning, you'll see a 3 TB and a 1 TB partition on the 4 TB drives (along with two very small partitions for the OS and swap).
    • DeepakSondur's avatar
      DeepakSondur
      Yes, you are right, both the Volumes are inactive.
      I am a Novice user and after i got struck into this issue, i did not use the NAS for an year now. The recovery from agencies is very very expensive.
      How to take a Back up?
      Can anyone help in guiding to take the backup?
      Thank you.
      • StephenB's avatar
        Guru
        It's too late now.  Paid support or data recovery software are your two options.
        Revisit backup in a followup here after you recover your volume.
ProSupport for Business
