semola1
Feb 09, 2025Tutor
Netgear RN102 Disk Upgrade
Hi All, I need to replace again my readyNas disks, because I have reached the maximum capacity of my current 10Tb drives. I wanted to ask you if, given that the RN102 box in my possession (updated ...
- Feb 10, 2025
Thanks for the advice you gave me.
Even though I would have spent less overall, given how I organized my workstation, I don't have space to physically place a 4-disk NAS (I looked at the dimensions of the RN104 and it is too large).
At this point I will try to look for some alternative 2 disks NAS and I will purchase two 18Tb disks at the same time with the new NAS.
Thank you
Semola
Feb 10, 2025Guru - Experienced User
semola1 wrote:
I wanted to ask you if, given that the RN102 box in my possession (updated to the latest firmware version) is old, I might have problems mounting 2 18Tb disks (Western digital WD181) that I found on offer.
While I'm not using these in my own NAS, they should work ok. There is no known size limit, and these are CMR drives.
Syncing the RAID array will take quite a while of course.
