gso's avatar
gso
Guide
Jul 11, 2023
Netgear rn21200 NAS
Have new Mac computer & need to delete existing Time Machine backup to start anew.
  • After I erased Sparsebundle, I was able to restart TM backup by clicking on "Enable" button to turn off (see attached pic), then immediately clicking on it again (to turn on). Type in new password, then click "Apply" & "OK". Started right up.
    • gso's avatar
      gso
      Guide
      No need for old Mac backup because I always seem need to start over with new Mac (not sure why). Thank you for your reply. I’ve seen that but don’t know which address to use to connect to server. Greg
      • StephenB's avatar
        RAIDar can tell you the IP address of the NAS.
        You can also find it in your router's attached device list.
        FWIW, you should also be able to use the NAS hostname.
ProSupport for Business
