jimmy_maxout
Dec 14, 2025Aspirant
Netgear Stora, mystora.com
Anyone who have a solution to my Netgear Stora. I want to survive it from not working. I accidently did a reset not remebering that mystora.com is down. 1.Can i make a user even if the cloud...
jimmy_maxout
Dec 16, 2025Aspirant
https://openwrt.org/toh/netgear/ms2000
is this a solution for my problem?
Dec 16, 2025Guru - Experienced User
Could be. Not a device I've ever owned.
It is really old hardware that is quite slow by modern standards, so you're probably better off just getting something newer. You'd need to go with another vendor, since Netgear no longer sells storage products.
Do you have files you need to off-load? It uses XFS formatting, so you can mount the volume on a linux PC (or off-load it with recovery software that supports XFS).
- jimmy_maxoutDec 16, 2025Aspirant
I have secured the files. The stora is perfect for my purpose so i want to revive it :)
- StephenBDec 17, 2025Guru - Experienced User
Hopefully the third-party firmware will deliver the features you want. Let us know how it goes.
