Leventh
Feb 04, 2023Apprentice
Netgear Terminating ReadyCLOUD Service
Since Netgear will terminate ReadyCLOUD service by April 1st, how can I access to my NAS device remotely? Is there any solutions/instructions by Netgear or anyone who can using other solutions? Thx...
- Feb 04, 2023
Yes, there are alternatives, which have already been discussed in other message threads..
A VPN hosted in your router and ZeroTier are the easiest/most secure, IMHO. You can also make provisions for remotely using FTPS or SFTP via port forwarding, but that requires you to either have a fixed IP or use a Dynamic DNS provider. There are even ways to use OwnCloud or NextCloud, setting up the shares you want to access as "external" (to OwnCloud/NextCloud). They also require a fixed IP or DDNS, but are a bit more secure (IMHO) than port forwarding.
As for why, it's very clear that Netgear is leaving the NAS market, though this will also affect a lot of their routers that offer it. ReadyCloud requires that Netgear maintain a server that acts as the "operator" to connect your NAS and app. And, of course, they have to do updates of the app as other OSes change and provide user support. Since they don't charge for it, they rely on new sales to fund it, and those have gone away as far as NAS are concerned.
Sandshark
Feb 04, 2023Sensei
- LeventhFeb 04, 2023Apprentice
Sandshark Thanks for clerification,
Good point to ZeroTier that I have used it before and it seems easiest way to setup, using as global network switch and I think, I can live with it.
In fact, I'm not at all surprised that Netgear quit the NAS market after some large companies cut staff and downsized. - IvanAlteyaMar 09, 2023Aspirant
Is DropBox a option? As of now, all my files are cloned in DropBox, because I use it generally only for security reasons. Will they stop support DropBox as well?
- StephenBMar 09, 2023Guru - Experienced User
No idea if they will update the third party cloud services if something breaks in the future.
Although they haven't said, my assessment is that they are quiet-quiting the NAS business.
