Leventh
Feb 04, 2023Apprentice
Netgear Terminating ReadyCLOUD Service
Since Netgear will terminate ReadyCLOUD service by April 1st, how can I access to my NAS device remotely? Is there any solutions/instructions by Netgear or anyone who can using other solutions? Thx...
- Feb 04, 2023
Yes, there are alternatives, which have already been discussed in other message threads..
A VPN hosted in your router and ZeroTier are the easiest/most secure, IMHO. You can also make provisions for remotely using FTPS or SFTP via port forwarding, but that requires you to either have a fixed IP or use a Dynamic DNS provider. There are even ways to use OwnCloud or NextCloud, setting up the shares you want to access as "external" (to OwnCloud/NextCloud). They also require a fixed IP or DDNS, but are a bit more secure (IMHO) than port forwarding.
As for why, it's very clear that Netgear is leaving the NAS market, though this will also affect a lot of their routers that offer it. ReadyCloud requires that Netgear maintain a server that acts as the "operator" to connect your NAS and app. And, of course, they have to do updates of the app as other OSes change and provide user support. Since they don't charge for it, they rely on new sales to fund it, and those have gone away as far as NAS are concerned.
Mar 16, 2023Guru - Experienced User
rodcrit wrote:
I note on the available Apps page of the Netgear system there is a VPN server which comes from Softether, which according to the blurb is better than OpenVPN. Anybody using this? I have installed the package on my NAS and downloaded the management service app on my pc from Softether web site.
This is not an app I use myself.
The version on the apps page is 1.5 (about 9 years old) so it is very out-dated. The current version is 4.41. The instructions on the softether web site might not match the old version you have. Updating it from ssh might not work, since the linux version in the NAS is also old.
Do you have a Nighthawk or Orbi router? Just wondering if it has OpenVPN built in.
rodcrit
Mar 16, 2023Luminary
Many thanks for responding to my plea for help. I have a BT smart hub 2. I don't know if this has OpenVPN, but have seen no mention of it in any documentation.
I confess I don't know where to go to from here.
it is annoying as I got the Netgear system because it had the readycloud facility which is relatively easy to use and now it is going to be terminated. I can understand why but means I can no longer use the system for what I designed it.
my daughter in America is the one most to be affected as she uses the system most for sharing stuff with her Sister, basically for free.
anyway thanks for response. will have to think where to go next.
- StephenBMar 16, 2023Guru - Experienced User
The documentation I am finding on-line doesn't have much content, but I am guessing that you don't have it in your router.
ZeroTier can be installed on the NAS, though it also can be tricky to set up. Sandshark has current experience with ZeroTier, so could help you through the setup here.
One non-VPN option is to use FTPS - which is encrypted. The FileZilla client would work at the two remote sites.
You'd need to set up some port forwarding in the router, and assign the NAS an IP address. You'd also need a DDNS service. There would be some configuration needed on the NAS side - setting the passive port range, and ensuring that the NAS won't accept unencrypted FTP.
Plex could also be used for media playing - but while the NAS does have a plex app, I personally think you are better off setting up that on a PC.
- SandsharkMar 16, 2023Sensei
See ZeroTier-as-a-ReadyCloud-replacement for more information.
