iancoleman
Nov 08, 2019Aspirant
Newbie Assistance Required - RN214 Transfer from PC
Hi Guys First post as a total newbie but in need of assistance if anyone is able. Trying to transfer ripped content from my PC to my NAS - have connected via ethernet from PC direct to NAS. When po...
iancoleman
Thanks for the quick reply. Yes - almost correctly. I probably wasnt clear - I have changed the last digit on my adapter settings but am using the IP generated when the NAS turned on connected to my PC. Assuming it doesnt matter what it is aslong as between 1-254 and not identical to the NAS?
The issue with connecting to the LAN on my router is that the PC is located at the other end of the house. Without running a monster cable I dont have that option. My NAS usually lives next to the router but its small enough to move to my study to plug in hence the direct connection.
Is there any way of making this work?
iancoleman
In theory could I buy a powerline adapter to run the pc back to the router and make the link that way?
