Stig78
Feb 27, 2020Aspirant
One disk gets redundant, rebulds, then another disk gets redundant. Now all dead. ReadyNAS 104
Hi folks. A few days ago my RN104 flagged my disk 1 as degraded. I did a restart on the system to see if it was only an error, and the disk started to re-build itself. I bought a new 8TB disk, h...
Stig78
Thanks for the answer.
I have not seen this before, and I do check now and then.
I am no expert at this, but I must have been looking at the complete wrong places. I guess just checking the status in RAIDar isn't enough...
Just checked my other ReadyNAS in the logfile you mentioned, and thankfully everything there is at 0.
Guess I'll just have to bite the bullet, by yet another HDD, rebuild the array and then check the remaining two disks to see how their healt is faring too..
Thanks again though!
Feb 27, 2020Guru - Experienced User
Unfortunately not. One issue with ReayNAS OS 6 is that it doesn't give you enough feedback on disk health. There are some alerts, but the thresholds for them are much too high.
