NetworkedinPA
Jan 13, 2015Aspirant
OS 6.2.2 UI Bug!
Hey guys, the OS 6.2.2 FW has a bug in the UI, seen both on 104 and now 316. The browser based GUI doesn't have any vertical scroll bars. Even zooming out doesn't always show all the info. The scre...
Jan 15, 2015Guru - Experienced User
That of course is how a normal sort of ASCII characters works out. Z is 0x5A, a is 0x61.
hmuessig wrote: If you choose Shares/Browse the shares are listed in alpha order regardless of case.
Not sure this is a bug exactly, I guess it depends on what you expect the order to be. Are you saying you'd like a case-insensitive sort?
For example
- h-whatever
iTunes
ITUNES
J-whatever
instead of
- ITUNES
J-whatever
h-whatever
iTunes
- Aug 28, 2016Retired_Member
