JonBServerGeek's avatar
Feb 02, 2021
OS 6 Drive upgrade
Good afternoon
I have a REadyNAS 312 running OS 6.10.4.  It's used for backups and rsync.
Currently I have two 6 TB drives in it.  Things are getting a bit tight and I will be putting in two  new10 TB drives,
I have done drive expansions a bunch of times on the older ReadyNAS Duos.
I read the page on Volume Expansion. and I have a couple questions.
On the presumption that I pull a drive, and then successfully install its larger replacement -- Will I need to perform any action on the admin page to trigger the expansion???
I seem to recall on the Duos, it mattered which drive you pulled first --  I am not 100% on that, I 'suspect' with OS 6 on the 312 it doesn't matter.
When the drive expansion is complete, I repeat the process
Have I missed anything here??
Thanks
  • Thanks for the quick and well-explained reply.  My bad on the typo, thanks for the fix
    Have a great day
    Jon B
  • StephenB's avatar
    FYI, I took the liberty of changing the title of your post from "OS 5 Drive upgrade" to "OS 6 Drive upgrade".
    Actually not.
    Netgear does recommend making sure you have an up-to-date backup before you begin (and I concur).  The volume is unprotected during the resync.
    If XRAID is enabled, then it should expand automatically.  You can check by looking for a green stripe on the XRAID control on the volume tab.  If the stripe is there, then XRAID is enabled.
    The system won't resync if the new disk is formatted - if that happens, you can select it on the volume tab, and format it in the NAS.  That should trigger the resync.
    The first resync will just recreate the RAID mirror on the replacement disk (syncing 6 TB).  When you replace the second disk, it should resync twice.  First it recreates the mirror (again syncing 6 TB).  Then it resyncs the remaining 4 TB - expanding the volume.
    I always recommend hot-swapping the disks, as then the NAS sees what you are doing, and doesn't have to figure out what changed while the NAS was shut down.
    • JonBServerGeek's avatar
      JonBServerGeek
      Have a great day
      Jon B
ProSupport for Business
