pgjscottieuk's avatar
Feb 15, 2017
OS6 Backup EXT4 or NTFS
Please before i do this which file extension should i use all my files on the Nas are large 5-35GB when reading about this the suggestion is EXT4 but what happens if i need to reinstate my nas from ...
  • StephenB's avatar
    Feb 17, 2017
    OS6 NAS uses btrfs for their file system.
    But I think there is some confusion here.  If the NAS is functioning, VLC would access and play the files using SMB.
    Since RAID is not enough to keep your files safe, I recommend backing them up (perhaps via USB drives).
ProSupport for Business
