Goliver
Nov 14, 2020Aspirant
OSX Catalina access problems
I recently upgraded to MACOS Catalina 10.15.7 Initially my Ready NAS worked but it subsequently dropped off the network and nothing I do will let me connect to it. READYCLoud web access works ...
- Nov 15, 2020
I'm not a Mac owner, so I can't offer much help. Catalina has been out a while, and there haven't been a lot of posts here on issues (though there have been a couple).
You might want to go to system->settings->services->SMB and enable "Legacy Windows Discovery" and "Enhance MacOS" and see if they help. Perhaps also enable UPnP.
If that doesn't help, you could try to add the NAS name and IP address to the Catalina hosts file. That should resolve any name resolution issues, but it is apparently isn't that easy to do. https://www.imore.com/how-edit-your-macs-hosts-file-and-why-you-would-want
If you do edit the hosts file, make sure you reserve the NAS IP address in your router.
But these steps won't resolve issues accessing the NAS by IP address (or issues with not being able to connect to https://nas-ip-address/admin). If you are using AFP for access, you might try switching to SMB.
Nov 14, 2020Guru - Experienced User
What firmware are you running?
Can you connect to the NAS from another PC?
Goliver
Firmare 6.10.3
I can connect to the NAS using its ip address and login as admin from Chrome on a Macbook Pro.
Finder was working on this MACbook but it just dropped access ..."Connection failed"
My IMAC cannot access the NAS with finder and trying to access admin using th ip address doesn 't complete
I am wondering if I should boot my NEST WIFI?
cheers
- GoliverNov 14, 2020Aspirant
PLEX access from a ROKU and READYCLOUD access continue to work
- StephenBNov 14, 2020Guru - Experienced User
Sounds like a good next step. Maybe reboot the NAS while you are at it.
thanks. wifi reboot had no effect on the problem
Maybe confirm that you can ping the NAS. https://support.apple.com/en-za/guide/mac-help/mchlp1003/10.15/mac/10.15
