btaroli
Dec 23, 2016Prodigy
OT: MIght see reduced forum participation after unannounced password rule changes
Just a heads up guys, since I have no real idea where to otherwise let you know... After using these forums for some time with a password-manager password of 40 characters and a wide array of cha...
btaroli
Jan 14, 2017Prodigy
I just had another run-in with this but now I see a pattern. It's "Community" that has this problem. I tracked down and reset a couple of old "MyNetgear" accounts, and used fairly long passwords with them, including a variety of symbols and whatnot. MyNetgear had zero problem with this and worked well.
The /problem/ came when I tried to reply to a thread in Community, which complained (as before) that I hadn't provided it a password. It seems that Community isn't able to support either the same /length/ of passwords as MyNetgear nor passwords with more complexity. So we have to dumb down our MyNetgear (and cloud, and and) passwords so that Community isn't bothered.
Is this something that could be addressed, so that there is parity in the support of password complexity across the web applictations Netgear makes available, especially considering that they share login information?
FramerV
Jan 16, 2017NETGEAR Employee Retired
Hi btaroli,
Thank you for the information. Let me see if I can check your inquiry.
