MikeR_EGV
Oct 26, 2020Follower
Permissions Reset Failed/ Access denied
Hello, I have an ReasyNAS 2312 with R231200 4x10Tb drives with over 20Tb used. This unit has been in production for less than 6 mos. We use AD authentication. Recently, all of a sudden users starte...
Oct 27, 2020Guru - Experienced User
It sounds like you've only been playing with file permissions. Have you looked at the network access controls? If users can't get into the share at all, then you do need to check the network access as well. Generally I recommend setting the file permissions to allow everyone access (both read and write), and manage access through the network access controls alone.
What happens if you run CMD on a PC, and manually enter the credentials?
net use * /delete /y net use t: \\nas-ip-address\sharename /user:username userpassword
using the real values instead of the placeholders of course. Start with admin, and the NAS admin password.
If you try this with multiple usernames, make sure you re-enter both commands, as you need to terminate any open SMB sessions before you change credentials.
Note I don't use AD, so I don't have any experience troubleshooting that.
