JS310
Aug 02, 2020Aspirant
Plex Media Server on ReadyNAS 2100 Questions?
I just brought a ReadyNAS 2100 home to test as a Media Server for Plex. Does anyone have experience with this device as a Plex Media Server? How does it perform? I just did a Factory Default comma...
Marc_V
Aug 03, 2020NETGEAR Employee Retired
Welcome to the Community!
Plex Media Server download link only has the version for OS6 if I'm correct but if you have a compatible installer that should still work.
You can download the RAIDar utility and proceed with the Factory reset and it should help you out on accessing the Admin page.
HTH
- StephenBAug 03, 2020Guru - Experienced User
Are you planning to upgrade the NAS to OS-6?
Note that plex no longer supports 4.2.x ReadyNAS (they dropped several platforms back in 2016). https://forums.plex.tv/t/armv5-powerpc-and-readynas-ros4-no-longer-supported-starting-with-plex-media-server-0-9-17-0/139976
- JS310Aug 03, 2020Aspirant
Oh WOW. This is great to know about Plex. I will def spend more time with my options. I am not able to get to the admin screen. The IP takes me to the shares page. The utility does not find the NAS on my network for somereason. A couple of hours ago I decided to follow the OS Reinstall boot and now I cannot ping the device at all. I am thinking that I need to find a way to do a fresh install of the OS to wipe out any lingering issues it seems to have.
I don't think this was a problem with the firmware install (though I can't completely rule that out).
Do another factory default. Then if you can't get in, please post screen shots from RAIDar and the web browser.
