sunsina
Aug 21, 2013Guide
Porting OwnCloud 5.0.10 to ReadNAS OS 6.0.8
I was thinking OwnCloud (OC) 5.0.10 is out for a while
I am wondering why the latest OC release is not included in the ReadyNAS OS 6.0.8 repository update.
Since there are a lot of performance and security improvements included in the OC latest release v 5.0.10.
The web interface updater add-on available for OC admin that comes with OC 5.0.7 will destroy the OC and makes
the OC web interface unavailable. :(
- super_poussinVirtuosoWait a little
- sunsinaGuideNow ReadyNAS OS 6.1.2 is out and OwnCloud 5.0.11
I decided to install via apt-get but after running apt-get update the repositories are updated on channel 6.1.1 ReadyNAS directory!?
I am wondering that ReadyNAS did not ease the task of OwnCloud updating via its WebPage, why one should update it via Plug-Ins or apt-get ! - super_poussinVirtuosoUpdate to 5.11 or 5.10 from GUI will break owncloud . A compatible version is on the road
- sunsinaGuideThe latest Version ReadyNAS OS 6.1.4 is out and having an Old Version of OwnCloud
I just use my ReadyNAS as TC and Cloud server (i only want ownCloud on my readyNas to service no other alternatives)
but still the buggy and old version of ownCloud is available as a plug-in.
I do not know why no one is interested to prioritize the update of ownCloud!? ownCloud server (5.0.12 is out) :-( - super_poussinVirtuosoI have done it but not published
- thomas2403AspirantSame here. I'm having that buggy version 5.07 (as a plug-in) too and eagerly awaiting the update. Any idea, when you can publish the new version?
- darklynxTutorI'm too would like to have the latest ownCloud.
Dear super-poussin, please publish the update as soon as you can!
Thank you very much for your work!
Best regards - schoemoeAspirantI'm interested in too very much.
- super_poussinVirtuosowill do
- thomas2403AspirantIt works perfect! Thank you so much, you did a great job.
