sunsina
Aug 21, 2013Guide
Porting OwnCloud 5.0.10 to ReadNAS OS 6.0.8
I was thinking OwnCloud (OC) 5.0.10 is out for a while
I am wondering why the latest OC release is not included in the ReadyNAS OS 6.0.8 repository update.
Since there are a lot of performance and security improvements included in the OC latest release v 5.0.10.
The web interface updater add-on available for OC admin that comes with OC 5.0.7 will destroy the OC and makes
the OC web interface unavailable. :(
- binford6000Aspirant@ thomas: Where did you get it from? There's no update since 6.1.4 and the owncloud update mechanism still doesn't work.
Removing and installing owncloud again from availbale apps still delivers 5.0.7... - super_poussinVirtuoso
binford6000 wrote: @ thomas: Where did you get it from? There's no update since 6.1.4 and the owncloud update mechanism still doesn't work.
check here : viewtopic.php?f=153&t=70914 - binford6000AspirantGot it running. Thanks, You're the man!
