FergyLergy
Jul 12, 2019Aspirant
Power Light Flashing
Hi,
Can someone please help?
I have just installed an RN21200 after the previous unit died. I have a few issues,
1. Blue power light is constantly flashing (unit is up & running fine!).
2. Unit does not recognise external backup drive when plugged into any of the USB ports.
3. When I log onto the unit via a browser it does not show fan speed or the UPS that is plugged in (APC CS350).
Don't know if this is of any importance but the 2 x SATA hard drives were just taken out of the old dead unit & installed into the new one with no setup required!
Thanks in advance
What NAS did you have before?
- FergyLergyAspirant
Hi StephenB,
Thanks for your reply & apologies for the delay!
The product number on the underside of the old unit reads - RND2000-200EUS.
A label above this also states model number - RND-2B
Just to confirm - does it say "Duo v2" on the front chassis?
If so, the drives are formatted differently in the RN212. Check the status with RAIDar (https://kb.netgear.com/20684/ReadyNAS-Downloads ).
It sounds like you have a backup of the old NAS - is that correct?
