nudist
Oct 17, 2016Aspirant
Problems configuring Flexraid
Have an R.N. 516 with 4 drives formatted for Raid5 . Bought two additional drive yesterday and intend to move to RAID 10 . I think I understand the instructions to get the machine into the right boot ...
nudist
So it's more of a conversion to RAID 10 then a clean installation . I'll take a lot longer but for the moment that seems to be the simplest way over the hump Thanks
- StephenBOct 17, 2016Guru - Experienced User
nudist wrote:
So it's more of a conversion to RAID 10 then a clean installation . I'll take a lot longer but for the moment that seems to be the simplest way over the hump ThanksIt is creating a new volume from scratch. It won't take longer than the old 10-minute RAIDar method.
If you have apps installed, it is best to uninstall them first.
