mHamstad
Feb 07, 2022Aspirant
Protection agains ransomware
Hi. Is there a script I can run on my NAS to protect it from ransomvirus. I was thinking something like; if I save an Excel fil I would have to enter a pin code which would be valid for a limited ti...
- Feb 08, 2022
mHamstad wrote:
I do have a portable disk that I backup the NAS to every third month, which my wife has in a drawer at her work.
Every file written to the NAS is also backed up in the sky. I don't know how well these files are protected against ransomware.
It's good you have a backup plan in place. The USB drive should give you good protection from a ransomware attack, as long as the attack isn't in progress when you make the backup. You could improve it by using two alternating drives (maybe backing up every month instead of every 3 months).
How well protected the cloud copy is depends on the cloud service. Many do have protection from ransomware attacks.
mHamstad wrote:
Is there a script I can run on my NAS to protect it from ransomvirus. I was thinking something like; if I save an Excel fil I would have to enter a pin code which would be valid for a limited time for that program. If I wanted to save a Word file I would have to enter that pin code again.
An interesting concept, but I don't know of any good way to implement it.
Feb 08, 2022Guru - Experienced User
mHamstad
Feb 09, 2022Aspirant
Hi.
Thx for your answer. I feel I am well protected, but just wanted to add another level.
cheers
Martin
