Nicholi
Oct 01, 2021Guide
PSA: Expired LetsEncrypt Root Certificate Potential Fix
For anyone on ReadyNAS 6 you may have noticed some issues recently with the machine being unable to work with sites utilizing letsencrypt certs. The solution first starts with assuring you have t...
Nicholi
Dec 14, 2021Guide
Additional note I just found since updating to ReadyNAS OS 6.10.6. You may need to remove the file again and re-run update-ca-certificates, as I believe some of the base level packages (which likely includes ca-certificates) get re-installed, so the old files get installed again.
This is likely a necessary step on any ReadyNAS firmware update.
Also the fingerprint of the old file if it helps anyone identify the bad root cert is:
$ openssl x509 -in DST_Root_CA_X3.crt -noout -fingerprint -sha256 SHA256 Fingerprint=06:87:26:03:31:A7:24:03:D9:09:F1:05:E6:9B:CF:0D:32:E1:BD:24:93:FF:C6:D9:20:6D:11:BC:D6:77:07:39
- ncameronApr 13, 2022Aspirant
I have done this, apparently successfully, on my ReadyNAS 314 - but I still can't see my Apps listed in LMS. Is there something else I should be looking for?
- JophusApr 13, 2022Luminary
May I suggest visiting RNXtras site and downloading his package to correct this. No SSH/commands just upload as an app.
Turn off LMS
Install app https://rnxtras.com/addons/letsencryptfix
Turn on LMS
Shout out to whocares as one of only a handfull in the community supporting readynas in a wholly voluntary capacity.
- ncameronApr 14, 2022Aspirant
****ing brilliant! That did it; after a system reboot. Been wrestling with this for months.
Happy to shout out to whocares, but never heard of it - how do I do that?
Thanks
