haachee
Aug 22, 2012Aspirant
Purchasing ReadyNas Pro 6 Diskless
Hello,
I'm an IT consultant for a small law firm. The firm is using about 3TB of storage and increasing.
I'm currently thinking of purchasing 2 ReadyNas Pro 6 Diskless units and I have a couple of questions:
1) If I purchase the Diskless system, what software is included in the system and what do I need to install in order for it to work?
2) I've had some issues with Seagate hard drives in the recent past, so I have a bad taste in my month from them. I'm debating on getting the Seagate Barracuda 7200.14 ST3000DM001 or the WD RED WD30EFRX. Seagate is selling for $50 less, so that's a $600 difference. Are there any performance differences in the hard drives?
3) I'm thinking of having the primary in the office and the other at the main attorneys home. Will he be able to access the data directly on the secondary device from his home computer and if so, will the changes he makes be reflected back on to the primary? That is, if I use the ReadyNas replicate feature, is it a two-way sync or is it only a one-way sync from the primary to the secondary?
I appreciate any responses and suggestions.
Thank you!
Thank you!
- claykinAspirant@haachee - You mentioned the lawyer has 50/50 Internet pipe in office. What does he have @ home? If he also has less than a 1Mb/s uplink then this will be the bottleneck. I would inquire to see if faster service is available for a reasonable cost.
